Switches Innerconnection
Nov 19th, 2007
I am working on a Campus InnerConnection project which involves connecting 14 separate buildings to a central office. I have designed the cabling structure where each building will have a MMF run to the central office and terminate at a Fiber Patch Panel. I have the core switch at the central office and would like to know how to innerlink each building to the core switch? For clarification, at the central office I have a C3500XL switch and would like to know how to connect all of the fiber from the Fiber Patch Panel to the core Switch.
Thanks in advance,
sK
Overall Rating: 4 (1 ratings)
s.marino Mon, 11/19/2007 - 11:43
Can you tell me the model of the core switch.
skhirbash Mon, 11/19/2007 - 11:48
It is a C3560 but can change it to suit the new deisgn.
sK
s.marino Mon, 11/19/2007 - 11:59
If you are connecting 14 separate buildings to a central office with MMF. One option is to use a Cisco 3750G-12S and a 3750G-24TS-1U and use them in a stack. The 14 fiber connection will be then connected (12)to the 3750G-12s and 2 to the 3750G-TS-1u.
s.marino Tue, 11/20/2007 - 05:08
If this helps in your decision please Rate it.
Best Regards,
snm
