SSH credentials in LMS 3.0
Answered Question
Nov 19th, 2007
Can anyone tell me where I can edit/add the SSH credentials for RME 4.1. Under RME/Edit Device credentials, I find only snmp, telnet, enable etc. but no option to enter ssh. however when I do a "Management Stn. to Device" check there is an option for "ssh" credentials.
Unless it is being called by anotehr name? I would like to do this (edit/add) ssh through the gui as well as bulk (via csv files)
Correct Answer by Joe Clarke about 8 years 11 months ago
Yes to all questions.
Overall Rating: 3.5 (2 ratings)
Joe Clarke Mon, 11/19/2007 - 11:52
LMS stores all credentials in DCR. The primary and secondary username and password credentials can be modified under Common Services > Device and Credentials > Device Management. The same credentials are used for telnet and SSH. The protocol used is determined by the various sub-application's protocol order.
srego4 Mon, 11/19/2007 - 13:59
Does this mean that I can use the same fields (primary username or secondary username ) for my ssh fields in the csv files as well for Bulk import?
If I do not use ssh v2 or acs for some devices, can I just leave the username blank and put in the password (telnet) and enable (enable secret)?
