Problem calling out -Cause i = 0x80B6 - Incoming calls are barred
Nov 19th, 2007
Dear All,
I landed in some issue with making outbound call from Phones registerd to CCM. Setup is depicted below
POTS-->PBX--->GW-->CCM
GW is configured as H.323. From PBX there is a PRI lines with 50 DID coming over to one of the controller in the Gateway.
Logs is mentioned below :-
70752 is registered with CCM
calling 19173495672
###########debug isdn q931 and debug isdn error message #####
Nov 19 22:10:48.329: ISDN Se0/0/0:23 Q931: pak_private_number: Invalid type/plan
0x0 0x1 may be overriden; sw-type 13
Nov 19 22:10:48.329: ISDN Se0/0/0:23 Q931: Applying typeplan for sw-type 0xD is
0x0 0x0, Calling num 70752
0x0 0x0, Called num 19173495672
Nov 19 22:10:48.329: ISDN Se0/0/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0089
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98397
Exclusive, Channel 23
Calling Party Number i = 0x0081, '70752'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '19173495672'
Nov 19 22:10:48.353: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref =
0x8089
Thanks in Advance
paolo bevilacqua Mon, 11/19/2007 - 14:48
  • Hall of Fame,
    Founding Member
The PBX is telling clearly that it doesn't accept this typo to call (it seems to me you expectation was that the PBX would send that to POTS). If you call a PBX extension does it work ?
In this kind of setups is generally better to have the router conencted to both PBX and telco, because the PBX can be difficult or impossible to configure for your needs.
manipandey Mon, 11/19/2007 - 15:28
The output provided was from the GW which is the cheese between two half of Sandwich(PBX and CCM)
No, I am not able to call the extension which are part of PBX.
This is the test phase and option of connecting GW to telco is ruled out. May be input specific to some instances when someone has carried out integration with existing PBX will help .
Thanks.
paolo bevilacqua Mon, 11/19/2007 - 15:32
  • Hall of Fame,
    Founding Member
Is the message the same when calling PBX extensions?
Ultimately you need the PBX configured for this work. What is it ?
manipandey Mon, 11/19/2007 - 16:03
This is the PBX setup for PRI coming to us.
** TRUNK GROUP DEFINITION
***...TRUNK GROUP........................413
***...TRUNK GROUP TYPE...................PRI
TCI...TRUNK CLASS IDENTIFICATION.........LOCAL CO
UGP...USER GROUP NUMBER..................107
VTT...VOICE TRUNK TRANSFER ENABLED.......YES
CNC...NATIONAL CALLING PARTY # CONTENTS..NONE
DCP...DISPLAY CALLING PARTY NUMBER.......NO
PND...PRIVATE NETWORK....................NO
***...LANmark PRI TRUNK GROUP............NO
TCM...TRAVELING CLASSMARK................NO
FTH...FAILURE THRESHOLD..................3
CHT...TRUNK MONITOR MINIMUM HOLD TIME....0
DCT...DATA CALLS ALLOWED.................YES
TCH...TRUNK CALL HANDLING................EXTERNAL
NDS...DISCONNECT SUPERVISION.............YES
IGG...IGNORE GLARE.......................NO
XFT...DISTANT IBX ALLOWS FEATURE TRANSP..NO
DPT...DTMF PASSTHROUGH TIMING INDEX......NONE
RETURN CONTINUES DISPLAY..... =>
......TRUNK DIRECTION....................BOTH WAYS
*** INCOMING PARAMETERS
STY...INCOMING CALL ORIGINATION TYPE.....PRI TRUNK
TYP...INCOMING TRUNK TYPE................DIALED AND DIRECT DIAL
ICM...INCOMING CALL MESSAGE #............NONE
WPR...WHISPER MESSAGE SOURCE GROUP.......NONE
NDC...NUMBER OF DID DIGITS TO COLLECT....5
PFX...PREFIX DIGITS......................NONE
APA...TRUNK GROUP AUTHORIZATION TYPE.....NONE
PVA...PRE-VALIDATE AUTHORIZATION CODE....NO
LVL...PREDEFINED LEVEL CODE..............NONE
TNE...TONE TABLE ENTRY NUMBER............NONE
RGF...DTMF RECEIVER GROUP................52
TOO...TIMEOUT TO ATTENDANT...............NO
RAC...REUSE AUTH FOR MULT. CALLS.........NO
CWR...CALLWAIT RINGBACK..................NO
UCT...TRUNK UPDATE CDR ON TRANSFER.......ALL
CPT...CALL PROGRESSING TONES:............IBX PROVIDED
IUG...InteMail LAMP MESSAGE USER GROUPS..OWN
NUG...INTER-USER GROUP NNP USER GROUPS...OWN
NDN...NIGHT ANSWER DIRECTORY.............NONE
TCT...STATION CALL RESTRICTION ENABLED...NO
8NC...800 TO 4D SPEED NUMBER CONVERSION..NO
NPB...NETWORK PLAYS BUSY SIGNAL FOR PRI..YES
NPR...NETWORK PLAYS REORDER FOR PRI......YES
NWT...CALL PARTY NAME WAIT TIME..........NONE
*** OUTGOING PARAMETERS
TXA...DIRECT TGRP SELECT ALLOWED.........NO
SLC...TRUNK SELECTION....................LONGEST
HDA...HARDWARE ANSWER....................YES
CXF...CANCEL TRANSFER....................NO
ICA...INTER-LATA CARRIER.................10XXX or 101XXXX
CPN...CALLING PARTY NUMBER...............SEND ALWAYS
CPM...CALLING PARTY NAME.................SEND NAME
PNN...ON-NET CALL: CALLING PARTY NUMBER..ISDN/TELEPHONY
PNF...OFF-NET CALL: CALLING PARTY NUMBER.ISDN/TELEPHONY
Thanks.
manipandey Mon, 11/19/2007 - 18:27
the above guide is ther with me too but regarding Intecom pbx talking to CCM, I didn't get anything as such ..:-(
Thanks anyway for ur help and concern...
