Message Notification every 5 min
Nov 19th, 2007
  • Bronze, 100 points or more
UM 4.2.1 - Message notification is sent every 5 minutes and doesn't stop.
Only set to "Work Phone" with
schedule of 24x7
restart notification eac time a new message
devise does not answer
8 rings
4 times
15 min btwn tries
device busy
4 times
5 min btwn tries
If notification fails, send notif to none
sopayne Mon, 11/19/2007 - 17:38
  • Cisco Employee,
Any chance you have the radio button "Repeat notification if there are still new messages after this many minutes" selected?
If not, you can get more details by enabling the Unity Diagnostic Tool>mAcro traces>"Traces for other Notification Problems"
I hope this helps.
aamercado Mon, 11/03/2008 - 19:52
I just followed sopayne's solution
jbarcena Tue, 11/04/2008 - 07:32
  • Red, 2250 points or more
Then you should have rated the Q and put the 'includes response(s) that solved Author's issue' mark so everybody else knows that it was fixed with that answer.
