LMS 2.6 missing RME
Answered Question
Nov 19th, 2007
Hi All,
I am experiencing a problem that my RME is not longer available from main menu. Right after I enable web encryption from common service. And I restart my server; the RME from my main menu is not longer showing and available to access it. When I got to Common Services and Software Center, Software Update it shows that I have RME 4.0.5 installed.. but I don't know why I can't access it from the main menu. I only have one standalone server and is running at LMS 2.6. Any opinions and suggestions are great appreciated.
JL
Correct Answer by Joe Clarke about 9 years 6 months ago
You will need to click on the Register button, then select "Register from Templates". Then select RME from the list, and click Next. Enter your server information. Finally, click Finish.
Overall Rating: 5 (1 ratings)
Joe Clarke Mon, 11/19/2007 - 18:22
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It may have been unregistered. Go to Common Services > Server > Homepage Admin > Application Registration, and re-register it.
jayshihlin Mon, 11/19/2007 - 18:28
Thanks for promptly reply. Actually I don't see RME under Application Registration..
I also check my licensing under Common Services > Server > Admin > Licensing
and here is the list of software:
Name Version Size Status Expiration Date
1. CM 4.0 Unlimited Purchased Never
2. DFM 2.0 Unlimited Purchased Never
3. IPM 2.6 Unlimited Purchased Never
4. RME 4.0 Unlimited Purchased Never
JL
Correct Answer
Joe Clarke Mon, 11/19/2007 - 18:38
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
jayshihlin Mon, 11/19/2007 - 19:08
Yes, it works. I don't know why it lost registration after I changed web encryption from enable to disable.
JL
