vkapoor5 Mon, 11/26/2007 - 07:12
  • Bronze, 100 points or more
The Clean Access Agent provides local-machine agent-based vulnerability assessment and remediation for Windows clients. Users download and install the Clean Access Agent (read-only client software), which can check the host registry, processes, applications, and services. The Clean Access Agent can be used to perform antivirus or antispyware definition updates, distribute files uploaded to the Clean Access Manager, distribute website links to websites in order for users to download files to fix their systems, or simply distribute information/instructions.
http://www.cisco.com/en/US/docs/security/nac/appliance/configuration_guide/412/cam/m_agntd.html#wp1222379
gojericho0 Mon, 11/26/2007 - 07:15
I understand its purpose. We are just looking to deploy it using a software distribution tool (Altiris). Normally the vendor provides various switches when running the msi to customize the install. By default Cisco creates a shortcut on the users desktop and I was wondering if there was an msi switch to make sure no shortcut is displayed
