pemasirid Mon, 11/19/2007 - 20:50
Check you console baud rate set correctly and config register value is set to 0x2102
Good luck
t_m0ceiwai Mon, 11/19/2007 - 21:05
Still doesnt work. Every time it boot still funny characters appear and if i press any button on the keyboard it in replaced with symbols. What do i have to do next??
pemasirid Mon, 11/19/2007 - 21:08
Check wether your flash card insert properly. Change the baud rate to 115200 and try.
t_m0ceiwai Tue, 11/20/2007 - 19:35
I off the switch on the Router inserted the flash card but it is still the same, everytime it boots funny character appear on the Hyper Terminal, even when i press a letter on the keyboard, it appears with some funny characters. Is there any possible solution for these problem ??
saimbt Wed, 11/21/2007 - 01:29
this is a classic case of mis-matched baud rates on the router and the PC.
You need to do a trail and error method and use the available baud rates from 110 to 921600.
I am sure this will solve the problem.
-Sai.
