Danged Practice Questions...
Nov 19th, 2007
Another example why these irk me:
1. Which two statements about the functions of a hub are accurate? (Choose two.)
A. A hub extends an Ethernet LAN.
B. A hub reduces the size of a collision domain.
C. Adding a hub eliminates the need for users on a network segment to compete for the same bandwidth.
D. A hub is a data link layer device.
E. A hub amplifies the data signal before retransmitting it.
I answered A and E
The correct answer was A and C
limseng80 Tue, 11/20/2007 - 04:06
I don't think C is a valid answer, a hub place users in the same collision domain, which means they are actually using the same bandwidth.
tperrier Tue, 11/20/2007 - 07:17
Was this taken from the infamous TestKing practice tests?...
pipemajor Tue, 11/20/2007 - 09:25
Uh, no. This is directly from... Cisco's own CCNA Prep Center page for the new ICND1 exam test questions.
jlhainy Fri, 11/23/2007 - 15:43
Even Cisco states that the practice questions do not simulate the actual exam. To some extent, I actually welcome questions that are wrong because it forces me to learn the technology & not just memorize questions, which is too easy to do. I used trancender for my practice tests and I found tons of errors. It is a pain, but because of it I did learn how things really work.
