Hi, [Pls Rate if HELPS]
All Switch Ports by default will be assigned to VLAN1
Try plugging a workstation, laptop, or whatever type of node that suits your fancy, and then go back to your terminal program to see if you get anything.
Go to VLAN1 configuration Mode
>>no shutdown
Pls Rate if HELPS
Best Regards,
Guru Prasad R
