Wireless Mesh Config
Nov 19th, 2007
Hi all,
I need to config wireless mesh system.
I have Wireless Control System, Wireless Lan Controller 2100, and access point 1310
Any one can tell me step to config this sys tem.
Thanks all, vote 5* for your help.
Overall Rating: 5 (2 ratings)
conkinkinconkinkin Tue, 11/20/2007 - 02:55
Hi all,
Thanks bbxie, I voted 5* for your help
I have AIR-BR1310G-A-K9, are you sure this product is not support mesh? Can you show me document to ensure that?
If it not support mesh, can i build wireless network with this access point and wireless lan controller:
- All ap use the same ssid, same security policy
- Roaming between wireless area
Can you tell me step to deploy that?
conkinkinconkinkin Tue, 11/20/2007 - 22:09
Any one can tell me step to config wireless network using accesspoint AIR-BR1310G-A-K9 and Wireless Controller 2100:
n.manlangit Sun, 11/25/2007 - 22:58
1310 is not a lightweight AP,, therefore it will not communicate with the lightweight controller 2100.....
conkinkinconkinkin Mon, 11/26/2007 - 04:20
I configed 1310 in lightweight AP mode, it joined Controller 2100.
Any one know how to config roaming in my case or it is default?
Richard Atkin Mon, 11/26/2007 - 04:21
  • Silver, 250 points or more
Roaming between APs on your WLC is enabled by default.
conkinkinconkinkin Fri, 12/14/2007 - 00:47
Hi all,
I configed wireless system with controller 2100 and AP 1310
Almost the time system run normally, but sometime one of AP 1310 reboot, but other still run normally.
I don't know why, do you have any suggest about this problem?
How to view log all event on this system?
Thanks all for help
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
