ASA 5510 basic configuration
Nov 19th, 2007
Dear all,
I wants to configure CISCO asa 5510.
My network is ADSL(Fix IP)--ASA5510--LAN
There is no DMZ.
ADSL ethernet IP:
firewall OUT side,
Firewall inside
I want one of my server have Public IP
I just add NAT on my ASA 5510 server) to
so i can connect from outside to this server. Am I correct? anything else i need to configure?
Jon Marshall Mon, 11/19/2007 - 23:28
Hi Daniel
Yes you need a static translation eg.
statc (inside,outside) 125.7.34.x netmask
and then you need to allow the relevant ports througjh in an access-list eg. for http
access-list outin permit tcp any host 125.7.34.x eq 80
then apply access-list to interface
access-group outin in interface outside
Don't forget that there is an implicit "deny ip any any" at the end of the access-list so any other things you need to give access to from outside to in should be included in the access-list.
andri.daniel Tue, 11/20/2007 - 15:37
Hi Jon,
Thanks for yor reply, I just configure my Cisco by ASDM and add access list on Security policy (see attachment for detail). Is it correct? Sorry for my stupid question, I am still beginner :)
andri.daniel Wed, 11/21/2007 - 17:57
This is my Cisco config:
asdm image disk0:/asdm-507.bin
asdm location Inside
no asdm history enable
: Saved
ASA Version 7.0(7)
hostname GACasa
domain-name default.domain.invalid
enable password xxx
interface Ethernet0/0
nameif Outside
security-level 0
ip address 125.7.xx.132
interface Ethernet0/1
nameif Inside
security-level 100
ip address
interface Ethernet0/2
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address
passwd xxx
ftp mode passive
access-list Outside_access_in extended permit tcp any host 125.7.xx.135
access-list Outside_access_out extended permit tcp any any
pager lines 24
logging asdm informational
mtu Outside 1500
mtu Inside 1500
mtu management 1500
arp timeout 14400
global (Outside) 100 125.17.xx.133-125.17.xx.137
global (Inside) 200
nat (management) 0
static (Inside,Outside) 125.7.xx.135 netmask
static (Outside,Inside) 125.7.xx.135 netmask
access-group Outside_access_in in interface Outside
access-group Outside_access_out out interface Outside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http management
http management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address management
dhcpd lease 3600
dhcpd ping_timeout 50
dhcpd enable management
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
: end
JORGE RODRIGUEZ Wed, 11/21/2007 - 18:24
Your config looks fine but in your access list you allow any tcp port you can leave it as is but I would do it as Jon posted it, be specific what tcp ports you allow inbound.
your config
could be as Jon indicated.
access-list Outside_access_in extended permit tcp any host 125.7.xx.135 eq 80
andri.daniel Wed, 11/21/2007 - 19:23
Hi Jorge,
Can I put like this:
object-group service openport tcp
description Port opened
port-object eq 5900
port-object eq 10601
port-object eq 6000
port-object eq 1601
port-object eq https
access-list Outside_access_in extended permit tcp any object-group openport host 125.7.xx.135 object-group openport
JORGE RODRIGUEZ Wed, 11/21/2007 - 19:48
Upsoluetly Daniel , you can ! and the access list is firm since you are now aware of which tcp ports are permited.
