FAC in Inter Cluster Trunk ICT
Nov 20th, 2007
I am trying to configure the FAC thru Intercluster. Calls are maturing if I remove the FAC from the Route pattern, when I enable FAC calls are not going thru.. I heard that there is a limitation in Inter cluster Trunk (ICT). If yes, can somebody give the URL to refer the same.
DK
sbilgi Mon, 11/26/2007 - 07:28
  • Silver, 250 points or more
There is a known issue CSCee75751 which is documented in the Cisco Bugtoolkit
