Multiple vlans is not working in 2950 switches
Nov 20th, 2007
I have created multiple vlans in my 2950 switch,which is connected to the router and for each vlan we have created subinterfaces
in router,we have shutdown the vlan 1 in switch.But at a time only one vlan is up and other vlans becomes shutdown.but I am not creating the vlans in the database,In sh interface trunk command the trunk ports are also showing.So please suggest us to solve the problem.
Jon Marshall Tue, 11/20/2007 - 02:07
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Jay
Could you just confirm that
1) You have created the vlans at layer 2 on the 2950 switch
2) You have configured the port connecting to the router as a trunk
3) The router has the correct encapsulations per sub-interface ie. if the vlan is 10
int fa0/0.10
encapsulation dot1q 10
ip address x.x.x.x x.x.x.x
Jon
Anonymous (not verified) Tue, 11/20/2007 - 07:25
andrew.butterworth Tue, 11/20/2007 - 08:47
  • Gold, 750 points or more
The 2950 is a layer-2 only switch and can only have a single Layer-3 SVI interface active at any time. What you are seeing is the correct behaviour for this switch (and any layer-2 switch).
Andy
glen.grant Tue, 11/20/2007 - 10:15
  • Purple, 4500 points or more
You are getting layer2 and 3 confused . The switched virtual interface on the 2950 is to manage the switch only so thus you only need 1 SVI up at a time . On your 2950 create your layer 2 vlan interfaces and then verify with the "show vlan" command . Those layer 2 vlans will then be trunked to your router , all your clients default gateways will then point to the router interface not an address on the 2950 because the 2950 has no routing capability. to create layer 2 , in config mode
vlan XX , then hit enter , this puts you into vlan config mode and you can give a name if you like or whatever other options you would like to add . Verify it shows in the table after with the "show vlan" command.
