Dialup AS
Nov 20th, 2007
  • Bronze, 100 points or more
We are using Cisco 3640 with two PRI E1s and two didgital modems. We would like to upgrade it to Cisco AS products, which platform fits our needs?
Thanks in advance
Abd Alqader
Michael Odom Tue, 11/20/2007 - 09:10
Depending on your scalability requirements, the AS5350 would probably be a good choice. You could also consider a 3800 if you don't need to scale any higher. I'd take a look at the cost between the two solutions and make your decision off of that.
a.hajhamad Tue, 11/20/2007 - 22:33
Thanks.
I think 3845 with NM-2CE1T1-PRI with two digital modems one with 36 ports and the other with 24 ports = 60 channels is good choice
thanks again
Abd Alqader
