irisrios Mon, 11/26/2007 - 09:11
  • Silver, 250 points or more
You can create apcf file to disable the toolbar. Then You will have to copy this file to ASA's flash as notoolbar.xml file and enable it.
Jason Gervia Mon, 12/03/2007 - 14:19
  • Cisco Employee,
Popup blockers will also kill the floating toolbar.
--Jason
