VSS 1440 vs STP+HSRP for highest core availability
yassine-m Tue, 11/20/2007 - 04:40
Each VSS system is composed of 2 Cat 6500 managed as one unit, VSS ensure a permanent layer 2 connectiviy between the two catalyst. So this solution bring a full redundancy by eliminating SPOF.
But if the two 6500s aren't configured as a VSS pair, and use STP+HSRP for the dual-connected server, iSCSI SAN hosts, and access layer switches, there's also no single point of failure. My concern is that the VSS system/protocol itself is newer, less known, and possibly more complex than STP. Essentially it boils down to a single mechanism to take care of the fail-over ... and I'm thinking I trust STP more than VSS!
Edison Ortiz Tue, 11/20/2007 - 18:20
  • Hall of Fame,
    Founding Member
Then I suggest contacting your Cisco SE and have a run on a VSS pair in your Lab until you feel comfortable.
Think of the VSS design as running a stackable 3750 vs 3560 with uplink ports.
