Phone ring 2 times and disconnect
Nov 20th, 2007
Hi.
I have continuos problems.
Now, with statis-tei 0 , the connection is ok.
But when i received a incoming phone, the phon ring 2 times and i can't answer the call.
This is debug.
017660: Nov 20 12:48:17.155 UTC: ISDN BR0/0/1 Q931: RX <- SETUP pd = 8 callref = 0x4B
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Progress Ind i = 0x8A81 - Call not end-to-end ISDN, may have in-band info
Calling Party Number i = 0x0183, '986715548'
Plan:ISDN, Type:Unknown
Called Party Number i = 0xA1, '948153108'
Plan:ISDN, Type:National
High Layer Compat i = 0x9181
017661: Nov 20 12:48:21.643 UTC: ISDN BR0/0/1 Q931: RX <- DISCONNECT pd = 8 callref = 0x4B
Cause i = 0x82E6333033 - Recovery on timer expiry
017662: Nov 20 12:48:21.647 UTC: ISDN BR0/0/1 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xCB
Cause i = 0x80D1 - Invalid call reference value
017663: Nov 20 12:48:41.715 UTC: ISDN BR0/0/1 Q931: RX <- SETUP pd = 8 callref = 0x4A
Sending Complete
Standard = CCITT
Channel ID i = 0x81
Calling Party Number i = 0x0183, '677983401'
017664: Nov 20 12:48:41.723 UTC: Failed to create voice call leg, rc = -25!!!
017665: Nov 20 12:48:41.723 UTC: Following traceback is for INFO ONLY. -Traceback= 0x6089DBCC 0x608C3CE0 0x608B7A68 0x608B99B8 0x6089FA30 0x6085FC0C 0x60861038 0x6086396C 0x6218DA8C 0x6218DA70
017666: Nov 20 12:48:42.743 UTC: Failed to create voice call leg, rc = -25!!!
017667: Nov 20 12:48:42.743 UTC: Following traceback is for INFO ONLY. -Traceback= 0x6089DBCC 0x608C3CE0 0x608B7A68 0x608B99B8 0x6089FA30 0x6085FC0C 0x60861038 0x6086396C 0x6218DA8C 0x6218DA70
017668: Nov 20 12:48:46.135 UTC: ISDN BR0/0/1 Q931: RX <- SETUP pd = 8 callref = 0x4A
Sending Complete
Standard = CCITT
Channel ID i = 0x81
017669: Nov 20 12:48:46.143 UTC: Failed to create voice call leg, rc = -25!!!
017670: Nov 20 12:48:46.143 UTC: Following traceback is for INFO ONLY. -Traceback= 0x6089DBCC 0x608C3CE0 0x608B7A68 0x608B99B8 0x6089FA30 0x6085FC0C 0x60861038 0x6086396C 0x6218DA8C 0x6218DA70
017671: Nov 20 12:48:47.163 UTC: Failed to create voice call leg, rc = -25!!!
017672: Nov 20 12:48:47.163 UTC: Following traceback is for INFO ONLY. -Traceback= 0x6089DBCC 0x608C3CE0 0x608B7A68 0x608B99B8 0x6089FA30 0x6085FC0C 0x60861038 0x6086396C 0x6218DA8C 0x6218DA70
017673: Nov 20 12:48:50.659 UTC: ISDN BR0/0/1 Q931: RX <- DISCONNECT pd = 8 callref = 0x4A
017674: Nov 20 12:48:50.659 UTC: ISDN BR0/0/1 Q931: TX -> RELEASE_COMP pd = 8 callref = 0xCA
Alfonso
vmoopeung Mon, 11/26/2007 - 09:35
  • Bronze, 100 points or more
A reason why you'll get a call drop as soon as its picked up after ringing is mostly due to incompatible capability information
negotiated on e.g. codec mismatch.
