Using fractional PRI, E1 for inbound and outbound calls
Paolo Bevilacqua Tue, 11/20/2007 - 09:44
Are you using CM, and if so with MGCP or H.323 ?
If H.323, place the isdn interface in trunk-group. Under said trunk group set the maximum number you want for incoming and outgoing.
interface serial x/y:15
trunkgroup mytrunk
trunk group mytrunk
max-calls voice 15 direction in
max-calls voice 15 direction out
dial-peer voice 100 pots
destination-pattern ...
trunk-group mytrunk
