"Wait while I transfer your call" greeting
Nov 20th, 2007
We just upgraded to Unity 5.0 and if someone calls a non-subscriber on the system and they do not answer....it says "wait while I transfer your call". It then sends them to the operator.
When we were running Unity 4.0.4, if the non-subscriber did not answer, it would tell them that the person is not available. Which is what I want.
Where do you disable that "wait while I" prompt on everything?
Rob Huffman Tue, 11/20/2007 - 06:46
Hi Josh,
Not sure if this is what you are looking for;
While Transferring, Notify Caller
Indicate whether Cisco Unity notifies callers when it transfers a call:
Check the Do Not Play the "Wait While I Transfer Your Call" Prompt check box if you do not want Cisco Unity to notify callers.
Uncheck the Do Not Play the "Wait While I Transfer Your Call" Prompt check box if you want Cisco Unity to notify callers and ask them to hold.
Default: Check box is checked.
From this 5.x doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/interface_reference/guide/dom/50curg070d.html
Hope this helps!
Rob
joshehaos Tue, 11/20/2007 - 07:11
how would you apply that to everyone? The box is checked. Would this be something used through bulk edit?
Rob Huffman Tue, 11/20/2007 - 08:44
Hi Josh,
How do these calls to non subscribers get to the Operator? I had figured probably via a Call Handler. If so this can be applied at that level.
Hope this helps!
Rob
