RME 3.5 and user field
Nov 20th, 2007
using LMS 2.6. When I add new devices using Common Service, i was able to defined users fields that i used later in CS to define groups
Want to do the same thing in RME but i don't find user field when i create a group ?
Any idea ?
Overall Rating: 4 (1 ratings)
Joe Clarke Tue, 11/20/2007 - 09:12
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
RME doesn't have its own user fields. However, you can make use of the same groups you configured in Common Services within RME.
gbusson Tue, 11/20/2007 - 23:35
how can i do to use the same group. I don(t find then when i want to define RME Group ?
Joe Clarke Wed, 11/21/2007 - 00:33
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You don't need to define a new group in RME. The Common Services groups will show up when you perform RME tasks such as config archive, software management, etc. You can use that CS group for all of those tasks.
Martin Ermel Wed, 11/21/2007 - 01:45
  • Blue, 1500 points or more
it is that you can make use of any group defined in one of the applications in any other application e.g. for to generate a report in RME
to see the system defined application groups you'll have to change the Device Selector Settings:
Common Services - Device Management - Device Selector Settings - Group Customization
look for 'Application Specific Group' and change it from 'This Application Group' to 'All Application Group'
If you define a Common Service Group with filter on the user field - this counts as a 'User Defined Group' and you can drill down to your group at this point in the Device Selector of any Application. So it is not necessary to have the possibility to define a filter on the user field in RME.
(What I do for User defined groups is to beginn the name of the group with the application in which it was defined (like CS_userField_01)- so I can find the filter definition quickly)
