Cisco WAAS deployments require that a Central Manager be deployed?
Nov 20th, 2007
I am in the process of setting up Cisco WAE running WAAS 4.0. One WAE will be in the branch and the other in the HQ data center.
My question is, is it a MUST that I have a separate WAE running as a Central Manager?
Overall Rating: 3.5 (2 ratings)
eng.usama Tue, 11/20/2007 - 22:45
i think the answer no & yes you can configure traffic interception then the 2 wae worked but it is so hard "nearly imposible" to edite default polices via CLI and the monotoring wil be so hard i tried to install the solution and implement polices then i disconnected c.m and it worked and connections optimized another point do you think you can implment CIFS server& client via CLI ??
Zach Seils Mon, 12/03/2007 - 06:22
  • Cisco Employee,
You can configure the base TCP optimizations (TFO+DRE+LZ) using just the CLI. However, the Central Manager is required for configuring CIFS acceleration, disk encryption, reporting, etc.
Zach
