failover
Nov 20th, 2007
I'm a little bit confused with the approach on how to get a failover with my current set-up.
From my attachment I want all my traffic will pass to primary router and split the internet traffic going to secondary router 3800 and my private corporate traffic will be taking the mpls serial 0/1/1. And it will also make a failover that all traffic to the secondary router when primary router fails. I'm using L3 switch where 2 routers are connected.
What is the best approach for this one?
Note: I have a tunnel from secondary router to pass my private corporate network.
a) Do i need to use HSRP?
b) Do i need to use dynamic local routing like EIGRP?
c) etc???
Please show me on how to start with the config.
Thanks!
yassine-m Tue, 11/20/2007 - 09:12
To help you I need the routing policy you choose. For me the traffic should pass through the L3 switch even if it comes from the MPLS router going to the Internet.
Br
jigz.bagsicjr Tue, 11/20/2007 - 10:35
so far i haven't yet started to make a draft of config. im hoping to get somewhat a thoughts on the best approach.
Thanks!
