CUCM 6.0 BE Help Files
Patrick Colbeck
Level 3
Level 3
I have installed CUCM 6.0 BE and when I loggin and click help I just get a 404 error.
HTTP Status 404 - /Help/en_GB/ccm/index.html
Strangel the help for Unity Connection works fine.
Any ideas ? Do I need to install the help separately ?
Pat
5 Replies 5
vnebolsi
Hi Pat,
Same here - new 6.0 BE install and no help files. Of course you don't have to install help files separately. Looks like a bug!
Cheers,
Vlad.
vnebolsi
Yes, it is a bug CSCsi04922 "Http error found on help page of all asociated items". It's fixed, but not clear what interim version.
Cheers,
Vlad.
kwangsuplee
I have same errors that I get a 404 error on help at CUCM 6.0.
Did you get fixed it up?
The workaround is to replace locale url to US one.
For instance if you have en_UK in the URL replace it with en_US.
Cheers!
Vlad.
vnebolsi
Cheers!
Vlad.
