Outgoing calls not working on the VG224
Nov 20th, 2007
Hi guys,
I'm able to receive calls from the vg224, but i can't make calls. Is there anybody familiar with this problem?
By the way my vg224 is connected to a CME.
kumar.vijayarajan_2 Thu, 11/22/2007 - 04:23
If you are using the H.323 configuration, check whether you have configured the correct
dial-peers with right destination pattern on VG224 and CME.
Kumar.V
valides007 Mon, 11/26/2007 - 07:35
I'm using SCCP. Regarding the destination pattern on VG224 i had to take it off, because when i tried to enable stcapp it didn't allow me saying that you can't have stacpp and destination pattern.
valides007 Tue, 11/27/2007 - 07:10
As i explained b4, while i'm recieving calls through the vg224 i'm not able to make calls.
Here is a copy of some of the configuration on the VG224 and the CME. Hope it will give you an idea about the problem:
VG224:
ccm-manager config server 10.1.30.100
ccm-manager config
ccm-manager sccp local FastEthernet 0/0
ccm-manager sccp
sccp ccm 10.1.30.100 identifier 1
sccp
sccp ccm group 1
bind interface FastEthernet 0/0
associate ccm 1 priority 1
dial-peer voice 1 pots
service stcapp
port 2/0
forward-digits all
CME:
voice-card 0
dspfarm
voice service pots
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
h323
sip
registrar server expires max 3600 min 3600
voice class codec 1
codec preference 1 g729br8
sccp ccm 10.1.30.100 priority 1
sccp ccm group 1
