3750 does not show some ports in entPhysicalTable
Has anyone seen this or know a workaround? 3750 switch 12.2(25)SEB4 the small-form factor GBIC ports do not all appear in the entPhysicalTable of the ENTITY-MIB. If I remove and then re-insert the ports that are missing, the port data begins to appear in the entPhysicalTable. If I reboot the switch, the data is missing again. I'd appreciate any help.
htarra Mon, 11/26/2007 - 13:43
I have several similar case for this issue, and we were solved by upgrading the device package.
Please upgarade to Cat3750.cv50.v5-1.zip.
this can be downloaded from
http://www.cisco.com/cgi-bin/tablebuild.pl/cview50.
After installing, reload the stacked device and then try to launch CiscoView. If the problem still persist please send me the output of SNMP walk of entPhysicalTable (.1.3.6.1.2.1.47.1.1.1)
I will see any try to resolved your Problem.
