In the middle of an upgrade from 4.0(2) to 5.x - first going to 4.0(4) (we're upgrading hardware as well.
Installing the 4.0(4) machine and to the point where I have to install the data store/SQL Server. I used the Preperation Assistant to install it on the 4.0(2) machine, but that prep assistant must not support Windows 2003 cause it won't let me past the prereq step cause it says Windows 2000 SP3 isn't installed, yes because it's windows 2003.
So, I'm trying to use the Data Store 2000 CD's that came with my 4.0(2) set. However, it's asking for a Product Key. All the CD's I have are in Cisco labled sleeves and I've got the entire set, just no product key on any of them.
What do I do? Can TAC get this number for me?
