11-20-2007 11:53 AM - edited 03-05-2019 07:32 PM
Would you please help me out on this, i have the following setup:
Extranet
Pix
Router
Core Switch
Edge Switches
The extranet is connected via VPN, VLAN1 is being used in addition to Vlans 2-10,
the router and the internal Pix interface are on the same subnet as VLAN1, IP routing is configured on the core and a default ip route to the pix is being used.
TO access the extranet static routes are being added on the core.
The problem is that except for Vlan1 none of the Vlans can access the extranet.
Can you please help me out to configure the core in a way that allows all Vlans to access the extranet
Many thanks
11-26-2007 01:46 PM
Could you provide the running configurtion. (sh run)
11-26-2007 05:34 PM
Ensure that you have a path back to the other VLANs via the pix and router. VLAN1 would appear as a locally connect subnet, the other VLANs destination addresses would have to be configured.
Allan.
