Allow VNC access to inside PC from the internet?
Nov 20th, 2007
I have a Cisco 837 just for home internet use. How can I allow VNC access (5800) or remote desktop (3389) from an external IP to my PC. Do I have to do port forwarding or something?
Attached is my config, I want to allow external IP 1.2.3.4 to my laptop on the VNC ports and remote desktop.
JORGE RODRIGUEZ Tue, 11/20/2007 - 14:09
  • Green, 3000 points or more
You could try this , say local information is, Local IP: 192.168.2.100 , Global interface: dialer1
ip nat source static 192.168.2.100 interface dialer1
to permit any from outside to 192.168.2.100 on port 3389 rdp.
access-list 104 permit tcp any 192.168.2.100 0.0.0.255 eq 3389 log
int dialter1
ip access-group 104 in
or
same static nat.
access-list 104 permit tcp host 1.2.3.4 host 192.168.2.100 eq 3389 log
int dialter1
Jorge
whiteford Tue, 11/20/2007 - 14:23
Thanks, the router gives out DHCP so I guess I would just give it a static ip like 192.168.2.101 as 192.168.2.100 is the router ip and add your rules?
JORGE RODRIGUEZ Tue, 11/20/2007 - 16:07
Yes, also make sure when configuring static in the PC that it also have dns information as well so that it can get to outbound internet, do c:\ipconfig /all on the other machines and take note of dns information.
Rgds
Jorge
