Rob Huffman Tue, 11/20/2007 - 16:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Mark,
Hope all is well with you :) The answer to this question is not really. Have a look at why this is;
RF Group Leader
The members of an RF group elect an RF group leader to maintain a "master" power and channel scheme for the group. The RF group leader is dynamically chosen and cannot be selected by the user. In addition, the RF group leader can change at any time, depending on the RRM algorithm calculations.
The RF group leader analyzes real-time radio data collected by the system and calculates the master power and channel plan. The RRM algorithms try to optimize around a signal strength of -65 dBm between all access points and to avoid 802.11 co-channel interference and contention as well as non-802.11 interference. The RRM algorithms employ dampening calculations to minimize system-wide dynamic changes. The end result is dynamically calculated optimal power and channel planning that is responsive to an always changing RF environment.
The RRM algorithms run at a specified updated interval, which is 600 seconds by default. Between update intervals, the RF group leader sends keep-alive messages to each of the RF group members and collects real-time RF data.
The RF Group Name is an ASCII string configured per wireless LAN controller (WLC). The grouping algorithm elects the RF Group leader that, in turn, calculates the Transmit Power Control (TPC) and Dynamic Channel Assignment (DCA) for the entire RF Group. The exception is Coverage Hole algorithm (CHA), which is run per WLC. Because RF Grouping is dynamic, and the algorithm runs at 600-second intervals by default, there might be an instance where new neighbors are heard (or existing neighbors are no longer heard). This causes a change in the RF Group that could result in the election of a new Leader (for one or multiple logical RF Groups). At this instance, the Tx Power Threshold of the new group leader is used in the TPC algorithm. If the value of this threshold is inconsistent across multiple controllers that share the same RF Group Name, this can result in discrepancies in resultant Tx power levels when the TPC is run.
From this good doc;
Radio Resource Management under Unified Wireless Networks
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a008072c759.shtml
Hope this helps!
Rob
Trending Topics - Security & Network
