CME Europe Dail Plan
hbarrera2
Guru's,
I have to install a CME/CUE in Amsterdam,Netherlands very soon. Does anyone have example confgs or know of a good document that shows how to set up the proper dial-peers for in/out phone calls for this area?
Thx
sebastiaanp
Here an example:
dial-peer voice 1 pots
description ** E1 PRI pots dial-peer **
translation-profile incoming Add-Extra-Digits-Incomming
incoming called-number .
direct-inward-dial
port 0/3/0:15
dial-peer voice 100 pots
description ** E1 PRI pots dial-peer national calls**
destination-pattern 00[1-7]........
port 0/3/0:15
forward 10
dial-peer voice 102 pots
description ** E1 PRI pots dial-peer local calls**
destination-pattern 0[1-9]......
port 0/3/0:15
forward 7
dial-peer voice 110 pots
description ** E1 PRI pots dial-peer 0800 numbers**
destination-pattern 0080T
port 0/3/0:15
prefix 080
dial-peer voice 120 pots
description ** E1 PRI pots dial-peer 090x calls**
destination-pattern 0090T
port 0/3/0:15
prefix 090
dial-peer voice 130 pots
description ** E1 PRI pots dial-peer international calls**
destination-pattern 000T
port 0/3/0:15
prefix 00
dial-peer voice 200 pots
destination-pattern 112
port 0/3/0:15
forward-digits 3
dial-peer voice 201 pots
destination-pattern 0112
port 0/3/0:15
forward-digits 3
Sebastiaan,
Awesome! Thank you sir for the example dial-peers. I believe they use FXO lines instead of a PRI, but I would think that the destination patterns would still be the same. Also what exactly are the 200/201 dial-peers for?
Thx again!
200/201 are emergency numbers. The number is 112 and 0112 is the number for users who dial the 0 for an outside line by mistake. See also 911 and 9911
