Aaron is very knowledgeable, but I would follow the cisco manual first.
7 Replies 7
scottmac
Level 10
Level 10
The cable is easy: each end of the connector is one pair, with the pins being the top-most and bottom-most pins on either side (pins 1&9 and pins 8&15 ... crossover 1->8, 9->15).
The problem is that a back-to-back PRI won't work. For ISDN, you need an intermediate switch (or device that looks like an ISDN switch).
You could probably do it as a T1, but without the intermediate switch, you won't even get L1 connectivity ("Multi-Frame Established")
Good Luck
Scott
Thanks Scott
Could you please refer me where have you found this ? and Are you talking about DB15 to DB15 ? because in the link that I have posted :
http://puck.nether.net/pipermail/cisco-nas/2003-December/000421.html
is different to what you have mentioned
that is not correct. After you have made the cable as indicated, just configure as detailed at:
http://www.cisco.com/en/US/partner/products/ps6350/products_configuration_guide_chapter09186a00800ca716.html
and PRI back-to-back will work without need for a switch.
Thanks P
could you please tell which one of those links that I have posted can be used to make a DB15 to DB15 cable, because I can see they have been using different pinouts assignments
Hi, any guide than mentions DB-15 is good, just cross tx and rx and is done.
Thnaks P
What confusing me is : when I compared between the link from cisco
http://www.cisco.com/en/US/products/hw/iad/ps497/products_installation_guide_chapter09186a008007e299.html
and the link below :
In the link from cisco (Table C-7: EI Interface Cable Pinouts) uses 6 (while other uses 4) pinouts :
Pin 8 --->1
Pin 15 --->9
Pin 7 --->2
Pin 9--->3
Pin 2 --->11
Pin 10 --->4
While in the other link uses 4 pintouts
DB-15 ----- DB-15
1 ----- 3
3 ----- 1
9 ----- 11
11 ----- 9
