ping problem
Nov 20th, 2007
Hi all,
one of my router interface is configured as
interface Serial1/0.1/3/6/2:0
description ##
bandwidth 1024
ip address 10.10.10.1 255.255.255.252
rate-limit input 1024000 192000 384000 conform-action transmit exceed-action drop
rate-limit output 1024000 192000 384000 conform-action transmit exceed-action drop
encapsulation ppp
no fair-queue
no clns route-cache
end
I am able to ping 10.10.10.2 but not 10.10.10.1 ---but i am able to ping this ip from other router --even i have tried with different source ip but not able to ping this ip anyway
pl. guide
regards
Mahesh
guruprasadr Tue, 11/20/2007 - 21:17
HI Mahesh,
bandwidth 1024
The Interface is already defined with the BW of 1024 only.
Why do you require a Rate-limit on input / output traffic ?
Whether U can't ping 10.10.10.1 from the same Router ?
Do add more INFO
Best Regards,
Guru Prasad R
mahesh-gohil Tue, 11/20/2007 - 21:21
Ya exactly
i am not able to ping 10.10.10.1 from same router but i can ping this ip from any other router connected to this router
mahesh
guruprasadr Tue, 11/20/2007 - 23:10
HI Mahesh,
Could you please check whether 1Mb link is fully over-loaded with the Input / output traffic.
Because during peak line load situation of Business Traffic, there could be a possibility of drop in SNMP, ICMP and some other traffic.
In this situation, the ICMP and SNMP traffic will be given low-priority.
Pls Rate if HELPS
Best Regards,
Guru Prasad R
ranjanibharadwaj Wed, 11/21/2007 - 13:04
Hi Mahesh,
On a WAN interface a simple ping goes out to the other end and comes back and gives out the result. Basically performs a small loop test for connectivity check and gives you the result. I don't know how your network is setup but I thought I will post this to just you an understanding that pinging itself own interface on WAN is different compared to LAN. You can check the ping times to realise this. ping times to 10.10.10.2 will be less than ping times to 10.10.10.1 (ofcourse when it works :)
Are you sure the link is up and there is no other circuit on a redundant router on which a similar interface is up?
I am not familiar with rate limit usage but like others have pointed out the problem might be because of that since pings sourced from the other end is working but from local router it is getting dropped.
Can you post the other end of the configuration?
Ranjani
