SENSOR INTERFACE OF IDS 4235 NOT COMING UP?
I have 2 IDS 4235 appliances running 5.0.1 version of ios.Since i have only two default interfaces, i have planned to keep it in promiscous mode itself with gig0/0 as sensor port and gig 0/1 as command and control interface.The sensor interface is not at all coming up when connected in the network.The same is the status even when i checked in the second 4235 IDS appliance.Where could be the problem.Do i have any cable specification for sensor interface.Neither is the interface comming up when checked with a cross cable connected to the laptop, nor is it coming up when connected with a straight cable in the network switch.Please provide me some suggestions on whats happening.I have as well attached the config and tech support.
regards...Jk
Please recommend on what best can be done.Is someone there??to help me.
regards..Jk
