VPN Client Autoupdate and Branding
Nov 21st, 2007
I have been able to 'brand' the VPN Client using a transform, OR automatically update the VPN Client software. I can't find away to automatically update the software AND keep the branding.
During Autoupdate a directory called 'install' is created in \VPN Client\updates\. This contains the unzipped new software. The company logos, icons etc must be in the install directory. The problem is that each time there is a software update the install directory is recreated so all the branding is lost.
Has anybody come across this and solved it?
stephenebdale Fri, 01/04/2008 - 02:19
Sorted this out. Need to include the branding png files within the zipped file containing the msi transform.
