thomuff Mon, 01/14/2008 - 13:11
Did you ever get an answer. I am running a Verifone Tranz 330 terminals on ATA. I am having intermittent problems. We have moved some of our terminals to dedicated POTS lines.
Paolo Bevilacqua Mon, 01/14/2008 - 13:17
first to note, fax/modem/whatever but human voice, connected to anything but FXS ports on the same router with POTS connections, is likely to give trouble.
Of course it is possible that your CC machine is so remote that the arrangement above is not possible.
This said, you should at the minimum specify which image type and version you have on the ATA, and if you have configured according to the guidelines for fax. The recommended image to do that, is H.323.
sohaildxbfze Tue, 01/15/2008 - 10:16
valuable info..
My case is
i want to connect POS machine to one of the VG port is is possible m running MGCP for vg.
thomuff Tue, 01/15/2008 - 12:36
I agree that it should not be used for modems. We are running these machines at about 20 locations. It works intermittently. Luckily, the machines are only used four or five times a month.
