Agent desktop disconnection
Nov 21st, 2007
Hello all,
I have an unsual issue with one of the 15 agents of the contact center : his agent desktop is disconnecting randomly. There is no network failure behind, so I don't know where the problem come from.
Do you have an idea?
Thanking you in advance
ecornwell Mon, 11/26/2007 - 06:08
We found an error once with the 7961 (or 7941) that was connected through a 2950 series switch. If you are using that combination, you'll have this problem. Basically if there is a 2950 switch anywhere between the 7961 and CCM the phone will unregister about once a day. The 2950 seems to eat a keepalive packet from the phone causing it to unregister for a second. The software is very sensitive to this.
Right now there is no fix action.
