11-21-2007 04:20 AM
what steps i need to do to check and save the configuration for PGW2200?
thank you.
11-27-2007 09:52 AM
Use command "prov-exp:all:dirname="some_directory_name" to save the config of PGW. Following link may help you
http://www.cisco.com/en/US/products/hw/vcallcon/ps2027/products_tech_note09186a008010ff0a.shtml
12-13-2011 06:04 AM
Hey there!,
Its simple..
Log in to your pgw
1. su-mgcusr
2. under mgcusr hit mml
3. Under MMl prompt
Let me show it to you
ind-pgwA mml> prov-exp:all:dirname="your_configuration"
MGC-01 - Media Gateway Controller 2011-12-13 13:29:43.997 GMT
M RTRV
"ALL"
ind-pgwA mml> quit
you can get your configuration under this path
ind-pgwA% pwd
/opt/CiscoMGC/etc/cust_specific
ind-pgwA% ls
1123 cisco kuns toolkit
LIabyrecreate ciscotac9 nad viren-isdn
LIabyrecreate.tar config-exported recreate your_configuration
abc directory1 repro
abu kunal sai
There you go!
Cheers,
Aby
