Cisco 878 SHDSL Router & Leased 'Copper' Line
Hi All,
Hoping you can help me out here. I have two brand new 878 SHDSL routers that I'm effectively configuring back-to-back via a leased copper line (4-wire variety). I've followed the sample config given on Cisco and all is well with the link establishing etc. however it won't pass any data. I'm sure it's something simple that i've missed so could you guys point me in the right direction as to what I'm doing wrong ?
I've attached the config from the CO end router for your perusal ...
Thanks in advance,
Stu
Try adding IP addresses to the point to point logical interfaces.
At CO end :
interface ATM0.1 point-to-point
ip address 192.168.1.1 255.255.255.252
At CPE end :
ip address 192.168.1.2 255.255.255.252
You will also need to add the respective routes for the "VLAN" subnets at each end, if your not using a routing protocol.
dsidley Thu, 01/03/2008 - 14:37
How did you fix it... using the recommended config additions ??
dsidley Fri, 01/18/2008 - 22:07
That would be excellent..
I have a couple of 878's in back to back with a dsl link..
These are in bridge mode and although a client connected to the CPE routers switchport works perfectly, I have no management capability for the routers themselves
The cisco tech recommended bridge mode as the simplest solution but in order for this to work I had to disable ip routing.
My goal was to have clients at the CPE side use the same local LAN subnet.
