Span session trafic seen in multiple switch
Nov 21st, 2007
in my Campus Lan, i've one core switch (4506) and several acess swicth (2950)
On an access switch i create a monitor sesion to get trafic for a particular port. Works fine.
On another switch (not in the same stack), i create another monitor session (with the same number) to see trafic for a particulor poirt on this switch. Works fine BUT i also see trafic from monitor on the other span session ?
I don't understand why. I don't use rspan.
Any idea ?
glen.grant Wed, 11/21/2007 - 05:53
  • Purple, 4500 points or more
If its a trunked environment you could see some of the same traffic.
Kevin Dorrell Wed, 11/21/2007 - 06:09
  • Green, 3000 points or more
Are you sure it is not just the broadcast traffic you are seeing? If so, that would be normal.
Kevin Dorrell
Luxembourg
gbusson Wed, 11/21/2007 - 09:20
No, i ve all traffic and the port spanned are not in trunk mode
