Does anyone implemented MSN blocking?
Nov 21st, 2007
I want to buy a AIP-ssm IPS for ASA 5510. Can I block msn ? Can I say this IP can use MSN but these are not ? is that possible ? I know that there is no user based configuration on IPS but is there a way to do that with IP ?
didyap Tue, 11/27/2007 - 14:41
You can block MSN using source IP. If for example you'd like the signature action to only apply to IP address
1. Default Action for signature 11201 is e.g. TCP Reset
2. Event Action Filter defines:
Source Address:,
cisco24x7 Sun, 12/30/2007 - 07:20
Are you sure about it? Have you ever done
it before? Let say I want to block
AOL instant messenging. How do I go about
doing on the ASA? Can you give a specific
example? Thanks.
Jens Becker Sun, 12/30/2007 - 10:05
You can't block AOL. MPF only supports blocking Yahoo and MSN.
The example of Cisco:
class-map imblock
match any // or acl
policy-map type inspect im impolicy
match protocol msn-im yahoo-im
drop-connection // or log , reset
policy-map imdrop
class imblock
inspect im impolicy
service-policy imdrop interface outside
i never tried, if the asa also discovers other protocols like AOL - don't think so, unfortunately.
