cant connect to server thru pix
Nov 21st, 2007
PIX 501 - unable to connect to / from server behind PIX 501 firewall.
inside 172.25.188.4
outside 10.25.188.4
server 10.25.188.5
traffic from 172.25.188.x needs to access server.
config:
PIX Version 6.3(5)
interface ethernet0 100full
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxxx
hostname POWfgMUSsal03dv
domain-name nowhere.it
no fixup protocol dns
no fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
no fixup protocol tftp 69
names
name 172.25.188.5 msvst
name 172.25.194.138 proxy
name 172.25.193.158 domain_controller
object-group network server
network-object msvst 255.255.255.255
object-group network clients
network-object 172.176.0 255.255.255.0
network-object 172.25.180.0 255.255.255.255
network-object 172.25.182.0 255.255.255.255
network-object 172.29.0.0 255.255.224.0
object-group network proxy
network-object proxy 255.255.255.255
object-group service msvst_tcp tcp
port-object eq 8080
port-object eq www
port-object eq https
port-object eq 1433
port-object eq 3389
object-group icmp-type icmp_allowed
icmp-object echo
icmp-object time-exceeded
icmp-object echo-reply
object-group service DCPorts tcp-udp
port-object eq 137
port-object eq 138
port-object eq 139
object-group network mgmt_access
network-object 172.25.176.0 255.255.255.0
object-group service mgmt_prots tcp
port-object eq ssh
port-object eq telnet
object-group service SMBPorts tcp-udp
port-object range 135 139
port-object eq 389
port-object eq 445
access-list inside_access_in permit icmp object-group clients object-group server object-group icmp_allowed
access-list inside_access_in permit tcp object-group mgmt_access any object-group mgmt_prots
access-list inside_access_in permit tcp any object-group server object-group msvst_tcp
access-list inside_access_in permit tcp object-group clients object-group server object-group SMBPorts
access-list inside_access_in permit ip any any
access-list outside_access_in permit icmp any any object-group icmp_allowed
access-list outside_access_in permit tcp object-group server object-group proxy eq www
access-list outside_access_in permit icmp object-group server any object-group icmp_allowed
access-list outside-access_in permit tcp object-group server host domain_controller object-group DCPorts
pager lines 24
logging on
logging timestamp
logging facility 7
mtu outside 1500
mtu inside 1500
ip address outside 10.25.188.4 255.255.255.0
ip address inside 172.25.188.4 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
nat (inside) 1 172.25.188.0 255.255.255.0 0 0
static (inside,outside) msvst msvst netmask 255.255.255.255 0 0
static (inside,outside) proxy proxy netmask 255.255.255.255 0 0
static (inside,outside) domain_controller domain_controller netmask 255.255.255.255 0 0
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
Jon Marshall Wed, 11/21/2007 - 06:56
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
The most obvious thing that stands out is that you have no global statement that ties up with the "nat (inside) 1 172.25.188.0 255.255.255.0 0.0" statement.
Assuming you want to Nat all your hosts to the IP address attached to the outside interface of your pix
global (outside) 1 interface
Jon
