Edison Ortiz Wed, 11/21/2007 - 07:54
  • Hall of Fame,
    Founding Member
Yes, you can configure IP SLA to ping a host and associate this SLA to a track.
On the HSRP configuration, you can use the track option instead of the interface.
Please read this chapter and at the bottom of the chapter, a HSRP example is illustrated.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hiap_c/haipbtrk.htm
HTH,
Nagendra Kumar ... Wed, 11/21/2007 - 09:04
  • Cisco Employee,
Yes you can configure "track ip route" command to achieve the same.
Nagendra
cisconoobie Wed, 11/21/2007 - 09:12
track ip route is not an option
Core(config-if)#standby track ?
<1-500> Tracked object number
Async Async interface
BVI Bridge-Group Virtual Interface
CTunnel CTunnel interface
Dialer Dialer interface
Filter Filter interface
Filtergroup Filter Group interface
GigabitEthernet GigabitEthernet IEEE 802.3z
Lex Lex interface
Loopback Loopback interface
Port-channel Ethernet Channel of interfaces
Portgroup Portgroup interface
Pos-channel POS Channel of interfaces
Tunnel Tunnel interface
Vif PGM Multicast Host interface
Virtual-TokenRing Virtual TokenRing
Vlan Catalyst Vlans
fcpa Fiber Channel
Nagendra Kumar ... Wed, 11/21/2007 - 09:24
  • Cisco Employee,
This command is a config mode command. Configure this command as below,
"track 1 ip route < ip addr/n> reachability"
and apply the same under interface using
int g0/0
standby 1 track 1
This will track the ip route and if the ip addr is not in routing table, the object will be down.
Hope this helps.
Nagendra
