Rob Huffman Wed, 11/21/2007 - 07:43
Hi Preston,
Good question!
The Cisco Aironet 1250 Series may be ordered as follows:
Access point platform with pre-installed radio modules: Includes the 1250 Access Point platform with pre-installed 2.4- and 5-GHz radio modules, or only a 2.4-GHz radio module. The combination of radio modules is determined by the part number.
Individual components: The access point platform (no radio modules) and radio modules are separately orderable as spares.
Cisco Aironet 1250 Series access point platforms with pre-installed radio modules ship with the following:
Cisco Aironet 1250 Series access point and radio module(s)
Mounting hardware kit
-One mounting plate, two 4 x 40 x 3/16 in screws, and a mounting plate latch (all attached to the access point)
-Two suspended ceiling T-rail clips, spacers (accommodates standard and recessed T-rails), and nuts
-Four 8 x 18 x 3/4 in pan head Phillips sheet metal screws
-Four #8 plastic wall anchors
-One 10 x 24 nut (for ground stud on the mounting plate)
-Two cable tie wraps
Product quick start guide
Translated safety warning document for the product
Cisco product registration card
Note that in contrast to previous models of Cisco Aironet access points, an external AC power supply and power cord does not ship standard with Cisco Aironet 1250 Series Access Point. An optional external AC power supply is available, but is required only if AC power will be used to power the access point. The external AC power supply is not needed if the AIR-PWRINJ4 power injector is used to power the access point; the injector has its own integrated AC power supply.
From this 1250 Ordering Guide;
http://www.cisco.com/en/US/products/ps6973/products_data_sheet0900aecd806b7c6d.html
Hope this helps!
Rob
