Upgrade software on WLC 4404 (there isn't enough space in the WLC)
Answered Question
Nov 21st, 2007
i've a controller with a version 3.2.xxxx
i must upgrade the software with a version 4.2, but when the tftp copy 16773120 bytes, tell me that there isn't space in the WLC.
How can i view the memory of NVRAM?
Can i erase the nvram and then copy a new file?
Exist a recovery procedure for the WLC?
THANKS
Can you help me?
thanks
fc
Correct Answer by Rob Huffman about 9 years 5 months ago
Hi FC,
Check out these notes;
Upgrades to 4.1-The TFTP server must support file transfers larger than 32 MB. Version 3.0 or later of Tftpd32 is recommended. If your TFTP server software does not support file transfers larger than 32 MB, then the upgrade does not complete (see the Troubleshoot section for symptoms). Note that several popular TFTP server software packages do not support file transfers larger than 32 MB.
http://tftpd32.jounin.net/tftpd32_download.html
Also, have a close look at the supported upgrade paths for WLC listed in this doc;
Wireless LAN Controller (WLC) Software Upgrade to Versions 3.2, 4.0, and 4.1
http://www.cisco.com/en/US/customer/tech/tk722/tk809/technologies_configuration_example09186a00805f381f.shtml
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Wed, 11/21/2007 - 09:02
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi FC,
Hope this helps!
Rob
