help needed upgrade catalyst 6506
Answered Question
Nov 21st, 2007
Can i upgrade a chasis 6506 with a sup720-3B + WS-X6724-sfp + WS-X6148A-GB. What is the difference between the chasis 6506 and the 6506-E
Peter
Correct Answer by buchholr about 9 years 3 months ago
Yes,
You need to upgrade to a "high-speed" fan tray (WS-C6K-6SLOT-FAN2) and your power supplies need to be 2500W or higher.
However, the 6148A card will see no performance increase. These cards are built with an 8 to 1 over-subscription, and are intended for wiring closet applications.
There are some enhancements to the backplane in the E chassis, and they can support more than 4000 W of power.
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
buchholr Wed, 11/21/2007 - 11:00
Yes,
Rob
pbogaerts Wed, 11/21/2007 - 11:58
Thanks Rob, but i thought that it was possible to make a etherchannel to other catalysts like the 4500 ? I would like to make an etherchannel between a copper sfp and this car
Peter
