Consolidating Unity 4.X servers
Nov 21st, 2007
I have about 20 remote unity 4.x boxes with off box exchange servers for the message store. The exchange servers are being consolidated. Is there a procedure for moving unity users with off box exchange mailboxes? thanks
Overall Rating: 4.5 (2 ratings)
ranpierce Wed, 11/21/2007 - 11:56
that is a good doc.
can I ask a question?
are all of the subscribers going to be in the same mailstore and server? and do all of the exchange servers see each other in you network?
I just want to make sure you get all the correct information for this.
rlp
balitewiczp Wed, 11/21/2007 - 12:07
The exchange servers will be migrated to a centralized cluster of about 5 servers.
I did find the doc, but it stopped at Unity 3.0 and above. All my boxes are 4.x I didnt know if there was anything more current.
ranpierce Wed, 11/21/2007 - 12:23
If all the exchange servers are in the same org and you can see the mailstore system manager, then you should be able to move the box through exchange.
rlp
