help configure VLAN with Cisco 2950
Nov 21st, 2007
I have Cisco Catalyst 4510R with two VLAN. Vlan1 and VLan2. I have a remote site that have a cisco 2950 switch. The remote site is connected to us directly. I want to be able to configure three ports on the remote site switch to be on and communicate with Vlan2 on the cisco 4510R.
Thank you
cisconoobie Wed, 11/21/2007 - 14:20
The 2950 is a layer 2 switch I believe so you need to make sure you have a trunk to that switch from the 4510.
Then on the 2950 configure the port like this:
int "port"
switchport mode access
switchport access vlan 2
johnisccp Wed, 11/21/2007 - 15:51
I am new to this so is there a way for me to find if there is a trunk to switch 4510R. The remote site is connect through a T1 internet line and traffice goes through Pix 515e.
