Installing PIX license
Answered Question
Nov 21st, 2007
Our secondary firewall crashed couple of days ago and we already got the replacement firewall. We are using PIX515E. I already got the license key from Cisco. What should I do first? Should I upgrade the PIX version first (because I needed to match the primary), install the additional NIC card, then install the license? Or the order doesn't really matter? Thanks.
John
Correct Answer by JORGE RODRIGUEZ about 9 years 5 months ago
Hi John, I would suggest to for 1st step install the NICS and lincese in any order it does not matter. 2nd upgrade code to match primary PIX code , and your final step connect failover cable for failover configuration sync at least at this stage you will have all physical and code matches before failover cable connections.
Jorge
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Wed, 11/21/2007 - 13:37
  • Green, 3000 points or more
Jorge
