VPN-Triple-DES is not enabled with current activation key.
cronustech
I would like to enable 3des on my new pix, can you please help me with this.
ajagadee
Please go to the below URL and log in using your Cisco ID and Password. Once logged in, you need to fill out a on-line agreement and then should be able to put in your serial number and generate a 3DES Key for your Pix.
www.cisco.com/go/license
Arul
** Please rate if the info helps **
