VPN Tunnel Working, cannot connect to remote networks?
tdobbs1013
Hi All.
I have a VPN tunnel between a Cisco 1700 Router and a VPN 3000 Concentrator. This tunnel is working great. The internal network is (192.168.70.x).
The internal network that the VPN Concentrator (192.168.10.x) is connected to is also attached to 3 other remote networks via Netscreen/VPN. (192.168.40.x, 192.168.60.x, 192.168.170.x).
My issue is, a user on the .70 network (tunnel between 1700 and VPN 3000) can not ping anything on the remote networks attached to the 192.168.10.x network.
I am not sure what to do, it seems as though I have tried everything, but am unable to get connectivity.
Attached is my config file on the 1700 router.
If anyone can help me out it would be greatly appreciated!
eberte
Maybe I'm wrong but I think your problem is in NAT.
What do you suggest I do to rectify it? I have assigned the proper addresses in my access-lists?
kagodfrey
Level 3
Level 3
Does the device on 192.168.10.x that your other remote networks connect into know the correct route back to 192.168.70.x is via the concentrator (and not, for instance, the default gateway)?
Kev
Hi, thanks for the reply.
The netscreen at 192.168.10.1 (whom all the other networks are connected to) does have a static route setup for the 192.168.70.x network to route to the VPN Concentrator (192.168.10.39). Without this route I couldnt do much on the .10 network.
When I do a traceroute from the 192.168.70.x network to a remote network it never gets passed the netscreen at 192.168.10.1?
Its really confusing me. I have even tried adding routes to the external networks firewalls.
